RCU Forums - View Single Post - C-160 Transall
Thread: C-160 Transall
Old 01-05-2004 | 07:01 AM
reixx
Default RE: C160
ORIGINAL: DocYates
If you are referring to the one by GSP, I have assembled and flown this kit. It looks very good, and flies well on two TT 25's. The landings are easy and it flies best at half throttle. The wing is junky and after and inflight failure due to a bad spar, I had to replace the spar and do some mods to the wing to get it flight worthy again. I lost an engine on about the 40th flight with this plane, and it occurred on takeoff (Landings on one are no problem). I accidently turned into the dead engine and it spun in, finishing off the wing. I tried with no success for the past 6 months to get a new wing from both GSP and othert suppliers and have no luck. They will sell me a whole new kit, but not a wing. I will cut my own out of foam one day and put it back in the air, but I am not doing business with them again.
Tommy
I recently purchased the camo version in November. They have changed the wing. Mine is built up balsa not foam. I know someone with the original C-160 and they have the foam core wing also. One other change that I have noticed is the engine nacelles have a better fit to the wing now verses the first kits. Other than these 2 items the kits are still the same.
