RE: Chicken Stick or Electric Starter
IF you plan on staying in this hobby then buy a starter that is rated for up to 90 size engines. Once an engine has started and been adjusted it is very easy to start but the first start of the day can take a bit of cranking. I consider a starter with at a 7 amp hour 12 volt battery one of the basics that you should have. m[8D]
