RCU Forums - View Single Post - TF Spitfire build
Old 01-05-2004 | 06:01 PM
tubig
Default RE: TF Spitfire build
doug, thanks for the comment. i'm doing my best to keep everything aft of the cg as light as possible (with the exception of buying contest grade balsa and doing it all over). if you don't mind i'd like to ask you questions on problem areas i may come across as i progress.
