RCU Forums - View Single Post - Twin Elevator Servo problem, help.
Old 01-05-2004 | 06:50 PM
Geistware
My Feedback: (16)
Default RE: Twin Elevator Servo problem, help.
This is a function of the servo/receiver and transmitter. My recommendation is to reduce the throw to balance the deflection up and down. Many people set up 3D flows and then dial in 40% rate reduction and 60% expo. If oyu reduce the movement of the elevator mechanically with 100% rate and the expo you need, it should be be less noticable. Going to digitals also reduces this difference in deflection.
