RCU Forums - View Single Post - Twin Elevator Servo problem, help.
Old 01-05-2004 | 11:21 PM
MikeEast's Avatar
MikeEast
Default RE: Twin Elevator Servo problem, help.
Im not sure about the servo speed adjustment on the 9C. As far as I can see in my manual there isnt anything on it.
I did swap the aileron servos and elevator servos to see if it was a servo problem. No difference. The servos are working perfectly now that they are driving the ailerons and the elevators are still acting up. Like I said I even switched to the best carbon fiber linkages and couplings I could get my hands on today and they are PERFECTLY aligned mechanically.
I think Im going to call futaba and see what they say.
Thanks a milion for all the input, suggestions are still welcome and I will let you know what Futaba says. [8D]
PS
Sal I caught your reply just before I posted this. Im going to read your post more carefully and see what you mean. I will let you know what comes of it.
Also you are right, the throws dont get out of square on low rates at all if I set my endpoints on low rate. (Which royally screws up the high rate)
AND on high rates both surfaces move together until you get out to about maybe 25 degrees. At 30 degrees things get really out of line until full throw, which is where the endpoint kicks in.
One more thing sal,
When I changed to Carbon Fiber today I set my linkages to where I am dead center and neutral elevator with no subtrim or trim whatsoever. I will have to adjust the up trim once I am in the air.
