The old AM radios had slightly different connections than the newer FM radios.
I did modify an old AM to be used as a buddy box. Not simple to do. I removed the tx board and battery. Then had to make a minor cicruit change. Also the old AM radios used a different servo center standard, so I had to readjust the timing.
Not recommended. Too much work as you can pick up a TX only real cheap.
Find someone who wants a flight pack. Buy a cheap radio, give him the rx/servos and take the TX.
Or just get the buddy box for $45:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLV14&P=7
