RCU Forums - View Single Post - AFP Serial Cable, Need Help !
Old 01-06-2004 | 01:40 PM
snakeeater
Default AFP Serial Cable, Need Help !
Hello All
I need as much information as I can get, I have beeh having issues with AeroFly Pro. I can't get the software to see my Radio (JR MAX 4), It is not a COM port issue because the software reports no errors. So my theory is that the computer can not see past the "dongle" to the Radio. I think I may have a deffective cable.....
My serial cable Stereo mini plug is connected as follows:
Tip(L) - White Wire
Ring(R)- Bare Wire
Sleeve- No Connection
NOW here is MY problem when I use any standard Stereo/Mono adaptor is connects both the Tip(L) to the Ring(R) (Which is fine when using headphones) BUT NOT when trying to transmit a signal. So how can there be people out there using the adaptor with JR the Radio.....It doesn't make sense
My only conclusion can be (Thus Far) is that I may have gotten a deffective cable, this is where YOU come in
My cable is connecter as follows:
Tip(L) - White wire
Ring(R) - Bare wire
Sleeve - No connection
(Attempt at own risk)
-Unscrew the black plastic stereo mini cover
-Inside you will see Three Solder points
-With the Plug end facing away from you the connection on the left is the TIP(L) & the one on the right is the RING(R), the one that crimps the cable is the SLEEVE.
-Take a look and tell me which one the white wire goes to and which the bare wire goes to
Thank you very much for any assistance you may lend to me
SE
