RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 01-06-2004 | 01:53 PM
  #745
bentgear
Default RE: U-Can-Do 3d 46?
A Saito 100 is not too much power if you know what the throttle stick is to be used for, nor is it too much additional weight. 16 x 4W prop clears the ground just fine.
Inverted enignes seem to be a flooding problem when they are new and just being broken in. After run for a while you can lean the low end a little, then just make sure the carb is closed before you fuel the plane.
Ed M.
