RE: Slow Stick Wing
The Slow Stick wing is foam. I had the same problem and used a heat gun. It dont take alot of heat to melt the foam, if you heat gun has a "Low" setting, use that and dont get it too close to the wing. When I did this I had someone else hold the wing and twist it back into place while I went over it with the heat gun.
