RCU Forums - View Single Post - prop balance
Thread: prop balance
Old 01-07-2004 | 02:01 PM
KidVermin
Default RE: prop balance
Not usually on the trainer size 9",10 or 11. It's when you get to the 12" thru 24" props that it is req'd. I've found that the standard Master Airscrew are the most out of balance from the factory. The balance helps to prevent excessive vibration.
