RCU Forums - View Single Post - Squirrely plane......? HELP ! HELP !
Old 05-22-2002 | 04:26 AM
Masonhornet's Avatar
Masonhornet
Default Wing secure..?
Seems obvious, but make sure the wing is very securely attatched to the fuselage. I don't know if this airplane uses rubber bands or nylon bolts to secure the wing in place, but if they are not tight enough the wing can seperate slightly from the fuselage in flight, and this can give you a wild ride for no apparent reason.
