RE: Reciever Wire Question ?
Your setup seems fine to me......where your antenna exits the plane from inside the fuselage, thread the antenna through a button. If the plane crashes and the wire is broken, it will be saved between the button and receiver, then you can solder on another piece. Usually you should always measure the length of your antenna just in case you have to resolder.
I have my antenna hidden inside the wing of my plane and it fly great without any glitches.
