ORIGINAL: wakbrdr
no no no, im dont think you are get my concept, the truck came with adjustable spacers, they go between the spring and the top of the shock, it does raise the hieght any, just presses down on the springs
Dude! Those are spacers for adjusting ride height only. You can put spacers on your shocks all day, it won't give you stiffer springs, just higher ride height. Imagine taking a spring off your shock and compressing it halfway, the stiffness of the spring will still be the same stiffness as your others when they are uncompressed. Ya dig? Spring rate is spring rate, it is what it is. If you want stiffer spring rate, get stiffer springs.
