RE: gp cub 40
Hello Guys,
Bloody foreigner giving you tips when my plane hasn't even flown yet!! The cub that I am building calls for a tail wheel to be located at the back of the fusx. I have purchased some extra and longer wire that is the same diameter as that supplied with the wheel and bent it to follow along the fusx and up into the rudder. This option gives you the added delight of a steerable tail wheel!
tell me it is bad, I don't mind but it has worked on the other cubs that have done the same thing.
Paul Man
Quote: "don't let the things you can't do [:@]
stop you from doing the things you can [8D]"
