RE: New Wing, Flight Trimming problems!
What type of setup are you using? Dual servos, torque rods?
Are you adjusting endpoints with your TX?
With your trim tab centered are you getting equal throws both up and down for both ailerons? Are they truly centered?
Adjust your trim tab to full up and full down. Are you getting an equal change up and down for both ailerons?
Based on your original post you might have some slop in your linkage or your ailerons are not in alignment. Depending on your setup you should have an equal adjustment for both left and right ailerons when you apply trim. Since you said after trim adjustment the left was down and the right was centered, I would look to make sure that both ailerons are working equal and opposite of each other.
Thank you,
Jerry
