RE: fox .40 carb replacement?
hey Racer I have a few suggestions. Is it stuck because of old oil in it? I fso try some spray carburetor cleaner. You can get some Gumout at any auto store. Another suggestion is using brake parts cleaner. It uses an alcohol type base and might work also. If it is corroded try some "PB Blaster". It is a penetrating oil spray available at auto parts stores. It comes in a yellow and white can. Soak it and let it sit for a few hours and soak again. You may need to do it several times but it should come unstuck. After freeing it up I would dissasemble it and thouroughly clean it. If not Fox still sells parts. Good luck.
Mark Shuman
