RCU Forums - View Single Post - To invert or not to invert
Old 01-08-2004 | 01:52 PM
Checklst
Default RE: To invert or not to invert
Most, not all 4stroke invert problems are the fuel tank position. make sure the center line of the carb is also the center line of the tank or Close. The old rule of thumb was no more the 3/8 of an inch up or down for a normal upright mount, invert should be even closer to center line if possible, if not possible use a regulator of pump.[8D]
