RCU Forums - View Single Post - MT2 problems
Thread: MT2 problems
Old 01-08-2004 | 07:29 PM
mecky33's Avatar
mecky33
Default RE: MT2 problems
There is a guy on here who made one and he says it stands up really well. And with the new era cage, its designed to run with no body thus no body mounts and posts to break. I have thought about doing that, just because I run my truck so much with no body on it. Your other option is to loosen the screws up a bit on the base of the posts and cut off the nub that holds the posts in place. Your posts will flex and twist out of the way when you roll, and when you put a body on it, they will hold the body in place pretty well. I have that set up on my truck right now because I haven't replaced the body mounts since I bought it. and with it being used when I bought it, the mounts where already broken in the way I described above. If you have questions about it I can try to take some pics or something.
