RCU Forums - View Single Post - han 9 edge
Thread: han 9 edge
Old 01-08-2004 | 07:35 PM
Jemo's Avatar
Jemo
Default RE: han 9 edge
If you use the recommended elevator throw for low rate it will not be snapping on you as some people have reported. I have had mine sooooooooooo Slowwwwwwwww, it has been scary, but never had a problem.
Some things to look for:
Check to see if the wingtips will match in incidence before gluing them together. It's better to have a mismatched center joint than having a difference in wing incidence. A friend just went through this with his. Also make sure the wing and stab are zero/zero. Some problems have arrived from not checking before gluing, you may have to make some adjustments.
If it's built straight it's a great little plane.
