RCU Forums - View Single Post - Sig 1/6th J3 Cub
Old 01-09-2004 | 12:57 AM
tubig
Default RE: Sig 1/6th J3 Cub
i've been able to work some on the wing. here is the right wing half. the kit called for a single servo with bellcranks to the ailerons. i chose to go with individual servos for each aileron. i've almost completed the compartment to hold the servo. you can see the triangular pieces i've used to hold the screws for the plywood servo cover. the piece of tape is just securing the string i'll use to run the servo leads to the center.
