Flip 3D Throttle Linkage?
Looking for help on throttle linkage hookup for Flip 3D with Saito 100. The throttle arm is quite close to the firewall at WOT and requires a large angle to clear the wing. I have several ideas but none are very appealing. Most have high drag or possible failure rate. others have RF interferance associated with a throttle return spring.
Has anyone reclocked the throttle barrel horn on this motor? I have tried to remove the allen set screw to remove the horn but it is very tight and feels like it will strip the allen socket before it comes loose or break my Snap-On allen driver. Starts to twist it now. Any help would be appreciated.
