Hawk Tail Wire
Here's another build question for my Hawk SE II.
When assembling the Tail Boom and wire into the main mechanics the flattened end of the tail drive wire goes into the tail drive output shaft but does not fit snugly as expected (there is some rotational movement of the output shaft before it makes the wire move).
And also having positioned the tail gearbox input grub screws over the flat on the drive wire then the wire does not fully engage all the way into the drive output shaft (there is still about 4mm before it is fully engaged).
Any comments ?
I was thinking of adding some heat shrink tubing over the flattened end of the drive wire to make a tight fit into the tail drive output shaft ?
