ORIGINAL: Shred
Hi
I have just bought a JR tx and wanted to use FMS but couldn't find a cable anywhere. After some searching, I found Smartpropo
http://www.sekiriki.jp/smartpropo/index.html . This lets you use a normal 3.5mm Audio cable to connect from your tx to your Mic in port on your sound card and converts the signal to input commands for FMS. Can't get cheaper than that!!!
Shred
Something you may want to check out: I have written a small app for PPJoy that reads your TX using the SmartPropo .DLL files (audio input) and creates a virtual joystick from that. So you can use those .DLLs with any program, not just FMS.
One catch: the SmartPropo .DLLs seem to produce access violations on some XP systems - including mine.
You can download PPJoyDLL from
http://deonvdw.netfirms.com/PPJoyDLL.htm
Regards
Deon van der Westhuysen
