Snaps with elevator G2
what you do is have a high rate with your 35 degrees of throw and a low rate with 10 degrees of throw put this on your radio switch, which will need to be at least a 5 channel radio; otherwise, you will have to use like the letter o, or p for a example as the 5th channel. you are burying the snaps at 35 degrees. most flyers only fly the 1/4 birds with 6-15 degrees of low rate throw and maybe 30-50 degrees of high rate throws on the elevator for the 3d stuff. remember that much elevator 35 degrees for normal snaps is to much......
