RCU Forums - View Single Post - How Much Flaperon Movement?
Old 01-10-2004 | 03:11 PM
CafeenMan
Default RE: How Much Flaperon Movement?
My experience is to start out with as much AILERON as you want. Then make the flap movement no more than half of that. Adjust after test flights. If you use all the movement with your flaps, then your ailerons will not be effective any more. I learned this the hard way with My Stik 30
