RCU Forums - View Single Post - Which 40 size Cap 232??
Old 05-23-2002 | 03:02 PM
Eohlin
Default WM CAP 232 40
I have the 40 size CAP from WM with a Saito 72 and a 14x6 prop.
Plane was a breeze to put together, everything fits well, the only change I made was to install an elevator bell crank in the rear of the fuse to keep the elevator halfs working well, I hate dual push rods.
Flying is effortless and I will do anything you ask of it. Landing is also easy, just make sure it's balanced correctly.
The only thing I would change is the motor...go with a Saito 91 and move the battery behind the wing and you will be set.
All in all I am very happy with the plane.
Good luck.
Eric
