RE: never mind
lynx, there is no bandwidth waste when you post something. all you end up doing is adding a few K to the hard drive on the server, and that isn't a big deal. Plus if it is such a problem for you, why did you reply? And also, the only reason a mod should see this, is because its a prime example of the lack of a delete button in the edit mode.
