RCU Forums - View Single Post - Tire problems
Old 01-11-2004 | 01:16 AM
fhm101's Avatar
fhm101
Default RE: Tire problems
If you buy preguled 8th buggy wheels, do yourself a favor and run another bead of CA around the joint on both sides. I've tried Medial Pro preglued and they were slinging off the rim. A quick zap of CA cured the problem. If the tread pattern you need is available pre glued, it's a no brainer.
