RCU Forums - View Single Post - BTE Delta Vortex Construction Photos
Old 01-11-2004 | 06:31 PM
SALMONBUG's Avatar
SALMONBUG
Default RE: BTE Delta Vortex Construction Photos
building the wheels well and the equipement control panel. this panel will be located under a hatch on the top of the plane. I still need to install a charging jack and a eagletree data recorder remote control panel on it wich are on order .
the equipement control panel access hatch will be closed using a spring loaded lock system (like on gliders canopy) for easy operations. I found that solution elegant. One hatch instead of a switch, charging jack air fill valve data recorder plugins, led and so on.......
on pics you can also see the airbotlle. That's the only element of the equipement wich will be inaccessible, but I never saw a airbottle fail.
ID:	89697   Click image for larger version
ID:	89698   Click image for larger version
