RCU Forums - View Single Post - OS 40 LA Engine
Old 01-11-2004 | 08:26 PM
RaceCity's Avatar
RaceCity
Default RE: OS 40 LA Engine
Sounds like a scratch in the piston. Over time, and after ingesting bits of foreign
matter...an engine will exhibit these. If you fly in a dirty, gritty location...expect to see
more of these. A bru-line air filter is a cheap means of limiting the amount of garbage your
motor is able to breathe in.
As long as you say the compression is good, and the motor is running fine, I wouldn't
lose any sleep over it.
Since there really isn't much in an LA motor to corrode...you might consider merely
keeping the motor tidy in your daily post-flight clean up, and minimize your disassembly of it.
Oil it up nice and it's good to go.
'Race
