RCU Forums - View Single Post - Seagull Spacewalker-any good?
Old 01-12-2004 | 09:28 AM
2mistakeshigh
Default RE: Seagull Spacewalker-any good?
Thank you both for the information. I am researching everything I can prior to heading out to the feild. I noticed you said that the throws were better at the high rates as the low rate setting are too low for a good flight.
I plan on setting this airplane up using the high rate throws for the low rates but would like to hear what you two have used for the high rate settings.
Thank you again for the information and I will let you know how it fly's with the Saito 72 installed. Just have to buy it first.
