RE: Location of BVM mixture control?
My advice to you is not to use the inflight mixture device. The Turbax I + OS 46 VXDF combination does not need an inflight mixture device. All you need is a remote needle valve (K&B has one, but I use the OS 91 remote needle with my VX) which you use to set the mixture on the ground and then go fly.
Peter
