RCU Forums - View Single Post - Location of BVM mixture control?
Old 01-12-2004 | 03:00 PM
Phil Cole
Default RE: Location of BVM mixture control?
While I haven't actually tried it a long piece of line between a needle valve and carb it shouldn't make any difference. The needle valve is just a restriction in the fuel feed which is adjusted to give the pressure to flow relationship required for the carb to do its job. The carb does not care how the fuel flow is restricted as long as it is consistent.
