RE: Has anyone used the razor saw by exacto?
zetor - If you plan to replace the hatch after cutting it out, you can drill a series of holes around the inside of where you would cut it. Make them as close together as possible and then connect them with a knife or the keyhole saw. A lot easier than trying to saw the plywood.
