ORIGINAL: RC Outlaw
This should put some wood on the fire, Any one that buy's this stuff takes full responsiblilty, you are the final builder ,whether you are a pro or a newbie at buliding!! You have to read the FINE PRINT the disclaimer, it usually is in or on the box some where! What you put on the nose is up to you and you pocket book. Just be carefill where you point it , It may be loaded!
Uh huh, and McDonald's didn't have to pay anything because of hot coffee.
If you build a plane put an engine outside the manufacturers specified range, that may be one thing, but if it is within in the range, and firewall pulls out causing injury, I doubt the disclamer matters. Just because there is a disclaimer doesn't mean they aren't responsible in a court.
