Gasser question
Brian said:
I made the cahnge to the low at 1-1/4 I did get more vibration at idle than before, should I richen the low end a little to get rid of this?
Yes, the timing is fixed, so idle will be a little ruff...You can richen the lowend at 1/32 intervels till you see a change in hover power..Leave your high where it is......If its idling high, move your trim to keep it low as possible..Only adjust needles for hover, and wide open...
If you see visible vibration in a hover on the heli(assuming everything is balanced) then its to lean on the lowend..
Never change the needles to you have cleared the engine, and it has warmed up...
Regards,
Bill
