RCU Forums - View Single Post - Gasser question
Thread: Gasser question
Old 06-17-2002 | 09:30 AM
  #39
Forgues Research's Avatar
Forgues Research
My Feedback: (7)
Default Re: Gasser question
Originally posted by Ergo60
I have almost 2 gallons through my new Z230 and it is still lacking in top end power. I am only running +8 on the top end of the curve, and it starts to loose rotor speed once it reaches this point. Hover is great at half throttle and about 5 Degrees. Anybody with any experience out there as t how long it will be before it starts to develope full power? I would think that this engine could pull +8 degrees with no problems.
Here is a picture of the plug. My needles are at 1-3/8 on low, and 1-1/4 on high, with AMSOIL at 80:1. It still looks like I am running rick, but I am a little hesitant to lean it any further.
Thanks.
You say you have nearly 2 gallons on your engine with still not enough top end. I beleive the problem is you need to do a proper break in first with non synthetic oil and then go to Amsoil. Right now your engine is not breaking in because of the Amsoil.
Amsoil is the best oil you can use in your gasser but only after it was proper broken in.....
