RE: Does conversion roughen an engine?
Actually the run smoother at idle because with the mag ign. they idle at full spark advance. With batt. ign the spark is around 5 degrees advance, as opposed to around 28 deg. A composite prop will help both run a little smoother as you say, because of the F.W. affect.
