ORIGINAL: iflynething
I have the Futaba 6EXA radio and am also setting up the flaperons, but when I turn the flap knob either way, the ailerons go up, instead of down. But the problem is that I am using two seperate channels (1 for right aileron, and 6 for the left) so I can't reverse the channel 6 that would be used for the flaps because the left aileron will reverse........I hope somone can help me.....THANKS......
Swap the aileron channels and then reverse the aileron channel. The ailerons should still go the correct way, but the flaps will reverse.
Did you try reversing the flaps? The radio may be smart enough to know what you want since you have the flapperon mix enabled.
