RCU Forums - View Single Post - How Much Flaperon Movement?
Old 01-13-2004 | 05:51 PM
iflynething
Default RE: How Much Flaperon Movement?
ORIGINAL: SeenMCrash
I'm not sure if your radio works like mine, but you go into the programming screen for flaperons. Set it to adjust:
Master: CH. 6 (flaperons)
Slave: CH. 1 (right aileron)
Reverse that channel. Doing so will make the right aileron now go down when you rotate the flap knob. Do the same process again, only this time, use this:
Slave: CH. 6 (left aileron)
Now, both ailerons should go down when the flap knob is rotated. This is how it is done on my radio, hopefully it is simialr to yours.
-Andrew
OK.......I just did what you said to so..........first I made sure that the right aileron was in Channel 1 and the left on was in Channel 6. They were. So, I went into the computer under P. Mix, and selected on.....I put channel 6 and the master, and then channel 1 as the slave. Then, I REVERSED CHANNEL 6, and then went back to the P. Mix and changed the Master and Slave to Channel 6.....I rotated the flap knob and the ailerons still were going the wrong direction, UP....Well, I hope that I can figue it out maybe Saturday when I take the plane to Hobby Stop. I think that they could figue it out because it is pretty hard to tell somone how to do something when you don't actually see what they are doing and you don't know how their radio works. Not to say that everyone's advice wasn't good, but, I will just goin to take the plane to the LHS anyways to let them check over the plane and everything; might as well see what they can do about the flaperons.....I might now even be able to have them.......THANKS AGAIN ANYWAYS.......
