RE: Seagull <span class=
[8D]Hello from Niagara Falls, I have one with a super tiger 45 in it, plane flys fine, i wanted to slow mine down a tad so I put an evolution 3 blade prop on it, looks great with the squared off tips, like a real turbo prop does. flys goood, only thing i don't like about mine is the tank seems small as I only get about 5 min of flying time, mine also was straight, balanced perfectly, no weight needed at all, another thing i did was put a thicker nosewheel wire on mine as it had a tendancy to bend on our rough grass fields here. Its hanging in our local hobby shop for the winter as i have a plane with skis i will be flying most of the winter, am building a cessena on floats right now that should work ok on snow tooo, I thought the seagull kit was of good quality, instructions sucked but the planes seems very sound, good luck with yours. Butch in Niagara
