RE: TF Spitfire build
sometimes you can "build around" the gear while you save up for them but I wouldn't recommend that if it's your first time with retracts. Top Flite's step by step method is designed just for you so do yourself the favor of staying with it. You will usually have to have the gear in hand fairly early in the building process so that gear rails and things like it all fit correctly.
Keep asking!
Mark
