RE: Elevator problem...
Hello Combatpigg,
I've tried every file format that RCU can take, neither of them have loaded my photo. I can e-mail the photos to you if need be. If possible, try to comprehend what the problem is.
OK, the elevator halves are joined using one servo with steel push rods. I've modified the push rod holders using obechi ply so there is no 'play' in control movement of the elevators.
I'm not interested about placing my Cessna 182 in Pattern Contests, so there is no concern there. The only concern is the 3 mm that the elevators are off.
Thanks for your reply and consideration,
Riccardo
