RCU Forums - View Single Post - Corona Tail problems, HELP! :(
Old 01-14-2004 | 11:09 PM
scimitar
Default RE: Corona Tail problems, HELP! :(
yeah its new.. i built it a while ago- but have been busy with other heli's since and now finnaly getting back to this one... the set skrews dont seem to hold so ill file the notch.. wish me luck!! i also played with a few setting on the TX - (so many settings!!!) you would think that by putting the tx in heli mode that it would be close to setup right for a heli- but seems like alot of tweaking is required... Im going to just check every end untill tommorow when i can put the tail together after filing... ill keep the board posted... Thanks a bunch for your help man!
ALSO- i cant seem to find pictures of any helis with the futaba gy401 gyro mounted on it.. i have it mounted "wall like" , i wonder if it should be mounted "floor like" .. Anyone know where i could find a pic? or know from experience?
Thanks!
