RCU Forums - View Single Post - Rudder-Throttle mix instead of Right Thrust
Old 01-15-2004 | 06:38 PM
myk
Default RE: Rudder-Throttle mix instead of Right Thrust
Looks good Marty, the only problem I see is that it is not adjustable after installation, I guess if the mixing works it would be nice because its infinitely adjustable at the field. How much R thrust are you guys using on the OMP 47" edge? And what kind of test are the best to determine if you have too much or not enough? thanks
