RCU Forums - View Single Post - Seagull Zero
Thread: Seagull Zero
Old 01-16-2004 | 07:51 AM
Mac-'s Avatar
Mac-
Default RE: Seagull Zero
ORIGINAL: motor710
I have been working on the Seagull Zero for two nights now and it is going together very well. My question is that the supplied fuel tank has a lip on it and I cant seem to figure out how it is to fit fully in the hole. Also I have never built a plane with a cowling and can not figure out based on the manual where the four wood blocks are glued on to attach the cowling. If any of you have built one of these any help would be appreciated.
Thanks Motor
Hi
I have the Seagull Zero ARTF and did an online build on another forum last year. It's a great model and flies well!
1) The supplied hardwood blocks are, imo, a little small but should be fitted where I have indicated in yellow - and the same on the other side, ie 4 blocks in total. Roughen the firewall first with glasspaper and epoxy into place with a drop of CA to hold in place while it sets.
2) Here you see one of the blocks from the bottom view.
3) Stick some maskimg tape on the fuse side and measure out to the block. With the blocks in place fit the cowl add some masking tape where it needs to be drilled and away you go. Easy![8D]
ID:	91019   Click image for larger version
ID:	91020   Click image for larger version
