Hi Furyicon,
I apologize, but other duties do not always allow us to answer as quickly as we would like.
With Flaperon active, I set up Airbrake, but zeroed out the elevator rate. I made the flap rate 100%. And I assigned this to switch E. To make this adjustable on the slider, I went into the FUNC screen and assigned the control of the Flap channel to the Left Slider. This give me flaperon with the stick, when I move switch E down it gives me full flaps, and with the switch up, I can adjust the flap action with my left slider.
Let me know if this helps you at all.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
http://www.futaba-rc.com)
