ORIGINAL: rfw1953
...Also used the stock spinner, but quickly found that the brackets failed with the starter. Too much torque for the brackets. I had the prop bolt drilled and threaded so I could use a True Turn spinner adapter. ...
After seeing the spinner and the way it is constructed I was wondering about its ability to take a high-torgue electric starter. My plans are to use a Sullivan Dynatron on 24volts. I could acquire a Megatron if I need it. I wonder if the Dynatron may also be too much for that spinner?
