RCU Forums - View Single Post - Vertical Stabilizer re-attachment?
Old 01-17-2004 | 07:38 AM
DBCherry
Default RE: Vertical Stabilizer re-attachment?
How much flex are we talking about? If you hold the top of the vertical stab and the rear of the fuselage, you shouldn't be able to move the "fin" without t the fuse moving. If you can, then some surgery is in order, because it's likely that your original epoxy joint (or the wood) is failing. []
Dennis-
