RCU Forums - View Single Post - How To After Run an Engine?
Old 01-17-2004 | 09:50 AM
1fstxnt
Default RE: How To After Run an Engine?
1st. make sure car is clean. 2nd. pull air filter off. 3rd. put 10 or so drops of after run oil down the carb. 4th. turn motor over a few times. 5th. put air filter back on. Make sure car is clean, you don't want to drop any dirt into the engine. I sure someone is going to tell you to just take out the glow plug and drop some oil down in her but don't listen. There is always dirt around the plug and you don't want oil around the plug collecting dirt.
